[ Total Views: 2412 | Total Replies: 51 | Thread Id: 18813 ]
Author: Subject: Subaru EJ25 Vehicle Speed Sensor (VSS)
MemberBoxersOnly
Threads: 1
posted on February 11th, 2004 at 03:54 AM
Hi All,
I was referred to this board by one of your members.
I'm in the process of swapping a '98 Subaru EJ25 engine in my 1970 Bug.
I heard some where that it is possible to mock up a VSS using a HAL (?) switch ?
Anybodu got any good info on how o build this ? I think you need to mount a magnet on one of the driveshafts, and then the switch recognizes the rotation ?
Thanks,
Rob.
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on February 11th, 2004 at 05:12 PM
Look at this post
http://www.aussieveedubbers.com/forum/viewthread.php?tid=14906
under the Subaru section, heaps of info :thumb
Membertonyg
Threads: 15
Mood: lost in the deep north
posted on February 11th, 2004 at 09:06 PM
gidday Rob,
just today i sorted out my speed sensor I think! Reed switch in back of speedo so is triggered by manet which operates the needle. I got the clue on how to do it from this link:
http://www.smallcar.com/speeds.htm
this seems to work fine (up to 135kph indicated but due to big wheels about 150 kph actual) which is as fast as i've been able to test it so far.
good luck
tonyg
they took me away haha, hope the medication works
MemberBoxersOnly
Threads: 1
posted on February 12th, 2004 at 01:17 AM
Good stuff, thanks guys, I'll take a look at it.
Rob.
MemberJenny
Threads: 20
Mood: Is it Friday yet?
posted on February 24th, 2004 at 01:08 PM
Check this post.
http://www.aussieveedubbers.com/forum/viewthread.php?tid=14864
The ECU on my EJ20 expects to see the VSS pin connected to ground 4 times per wheel revolution. The Vanagon uses a reed switch and magnets in the speedo drive to achieve this. I think the same setup can be applied to the 1990's vintage EJ non-turbo Subarus.
Kombicol has adapted a Commodore optical VSS.
I plan on using a hall sensor and some magnets on the CV.
MemberTransparu
Threads: 71
Mood: GREAT!!
posted on February 27th, 2004 at 08:16 PM
A friend has been with Telstra (Telecom) for >30 years and dealt with reed switches.
He responded to my question thus:
( He is NOT favourable disposed to my Transporter campervan, nor impressed by its performance.)
I would not use a reed relay. Consider this. An average car probably has a wheel rotation of 500 rpm. Therefore the Kraut Kramper would be roughly 250 rpm except when it is coming down the hill at West Ashgrove. You require 4 pulses per revolution. This means that the reed relay is operating at 1000 operations per minute.
This means the reed relay would operate 60,000,000 times per 1000 hours of use of the KK. I used to know the life of a reed relay because hundreds were used in an Ericsson telephone exchange. What I do know is that the quality of reed switches you would buy in Brisbane would be such that they probably have a life of only a few hundred thousand operations if you are very, very lucky.
FWIW
Dave
MemberTransparu
Threads: 71
Mood: GREAT!!
posted on February 27th, 2004 at 08:28 PM
I've attached a file describing a Hall Effect VSS. The Allegro UGN3060KA sensor can be had as a free sample from the US manufacturer (even to here in Australia) if you only ask for 2. There are NO other parts other than magnets and cable.
This VSS works for me.
I wish I could recall who in the US sent me the circuit.
Dave
Memberseagull
Threads: 714
posted on July 29th, 2005 at 01:12 AM
I have 5 peices of the new series hall unit comming from the USA in the next few days .
I would like to know your thoughts Jenny on proximity units like ( sick ) or PP units .High speed ? what to ask for ect , these are just look like a easy way of mounting > have a thread with two nuts pree wired better IP rating ect
like I said just your thoughts and part numbers> links ect Jenny :) seagull
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so temperamental.
MemberJenny
Threads: 20
posted on July 29th, 2005 at 08:38 AM
Time for some math:
Using 4 pulses per wheel revolution and a 205/70R15 tyre. This has a diameter of about 0.668m and a circumferance of about 2.1m.
At 100km/hr you have about 47619 wheel rotations at 4 pulses/rotation = 190476 pulses in 3600 seconds = 52.94pulse/second or Hz
Your sensor needs to operate over the range of about 1Hz to 100Hz, which is not high speed.
In order for the sensor to act like the reed switch and connect the ECU pin to ground you will need one that has an open collector NPN transistor output. If you're keen then have a read of this http://www.allegromicro.com/techpub2/an/an27701.pdf
There is also good info available at the Honeywell and ASSMtech web sites.
ASSEMtech have a fully encapsulated one (at least IP55) part PSS25S/30, available from Farnell. Note that the cheaper proximity sensors are actually only reed switches. The hall type ones start at about $50
nn[ Edited on 28-7-2005 by Jenny ]
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on July 29th, 2005 at 09:36 AM
I plan to use one of these mounted at an inner CV with a star shaped piece of metal attached to the CV. The points of the star would pass through the sensor. It is an On/Off hall effect device in a robust case, seems ideal.
http://www.jaycar.com.au/productView.asp?ID=ZD1900
Only AU$20.
Membergull
Threads: 34
posted on July 29th, 2005 at 12:02 PM
Thanks mike , I did ring jaycar about this one , told me no stock , rang again to day , yes we have stock now ! I off to get one .
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on July 29th, 2005 at 12:20 PM
Didn't you just say that you have 5 coming in from the States?
I'm confused.
Memberseagull
Threads: 714
posted on July 29th, 2005 at 09:53 PM
Thanks for your post Jenny well done .I wish you lived down the road I am sure our projects would be running at the same time by now .
Yes thats correct Mike > long story but there samples comming from the USA , this takes 2 to 6 weeks .I need one now so purchased the jaycar unit today , what a shop ! have some great gear , I must get out my office more I did not know this place was even there , all types of kits you can make .
seagull
O I post you one when ( if ) they turn upnn[ Edited on 29-7-2005 by seagull ]
Memberseagull
Threads: 714
posted on July 29th, 2005 at 10:06 PM
Just a thinking have a look at the subaru main pully , mine has 4 x 8mm holes spaced in it same size as the magnets I have , the unit from jaycar fits behind the pully bolted to the cam covers .
just an idea ? seagull
MemberJenny
Threads: 20
posted on July 30th, 2005 at 07:25 AM
Neil if you drive it off the main pully you would be counting engine RPM, I thought you wanted to measure road speed? What are you using as your speedo on the trike? If you're using a normal motorcycle one with a mechanical cable drive off the front wheel then you may be better off buying that VDO part 412.009 and fitting it between the cable and your speedo. See catalogue page 66 & 67 herehttp://www.siemensvdo.com.au/files/2388_VDO%20CATALOGUE.pdf
The Jaycar sensor does not sound like an open collector type but, as I don't know the ECU circuit, it may still work.
The trigger disc for that type of sensor normally looks like an upside down small metal cup, with notches cut out of the lip. The lip with notches goes through the slot on the sensor making it switch, but the star shaped disc that you describe Mike should work too.
nn[ Edited on 29-7-2005 by Jenny ]nn[ Edited on 29-7-2005 by Jenny ]
Memberseagull
Threads: 714
posted on July 30th, 2005 at 12:08 PM
Hi Jenny , yes its a motor bike speedo , I dont have any space to fit the vdo unit .
I found the Jaycar switches with magnets as well ( it did on the bench ) but I am machining a metal disk to day to do as mike is saying to fit to the cv flange.if this works I lazer cut some out .
cheers neil
Memberseagull
Threads: 714
posted on July 30th, 2005 at 10:48 PM
My set up I doing this weekend , making and mounting of the metal starplate to cv .I be making the bracket for the hall unit tomorrow .
Memberseagull
Threads: 714
posted on July 30th, 2005 at 10:52 PM
Mounted the plate to the back of the cv , I removed the three retaining plates ( stock vw ) .I will make an ajustable braket of the swing arm to mount the hall unit to .
Memberseagull
Threads: 714
posted on July 31st, 2005 at 09:31 PM
the finished uint mounted and wired to the ecu
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on August 1st, 2005 at 10:04 AM
Seagull,
Looks good. My idea came to life and I didn't have to do anything! You've basically done what I planed to do. Only difference is I'm hoping to mount the star on the inner CV and make a bracket mounted under the clutch tube bracket to hold hall effect .
My car is only a few months away from needing this so I'm keen to hear how is goes.
Keep us informed Neil!
Memberseagull
Threads: 714
posted on August 2nd, 2005 at 12:55 AM
Mike I found the small amout of play in the inner cv would collect the hall unit and smash it .
just hang in there as the samples are on there way , these may be better for a buggy set up .what I have will never see off road work , when you see it you will understand .
Neil
Memberseagull
Threads: 714
posted on August 6th, 2005 at 09:02 PM
Mike the units arrived on friday ( 10 peices ) I load a photo soon .
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on August 8th, 2005 at 01:19 PM
Cool!
Memberseagull
Threads: 714
posted on August 11th, 2005 at 01:43 AM
Mike the units are ( ICs ) you would need to make the unit up
if some one would like to ( can do ) I will send these to them , may be we can sell them off & funds to the fourm ??
I have 10 peices here .
MemberJenny
Threads: 20
posted on August 11th, 2005 at 10:06 AM
what's the manufacturer & part number?
Memberseagull
Threads: 714
posted on August 11th, 2005 at 08:11 PM
Allegro Micro systems
Ic part number A1421LK
Hope this helps Jenny
Memberseagull
Threads: 714
posted on August 18th, 2005 at 11:45 PM
Any good to you Jenny ?
MemberJenny
Threads: 20
posted on August 19th, 2005 at 07:00 AM
I can do some experimenting with them, but they are not the open collector output type, so I can't guarantee they'll work.
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on September 1st, 2005 at 05:16 PM
Any more happening on these?
Memberseagull
Threads: 714
posted on September 2nd, 2005 at 12:06 AM
no Mike its easy to get the one from jaycar , the other set up is lots of work .
Powered by UltimaBB, © 2004-2007 The UltimaBB Group
Copyright © 2002-2008 Aussieveedubbers. Aussieveedubbers is not responsible for members' posts.
[ Queries: 31 ] [ PHP: 27.6% - SQL: 72.4% ]
