This forum is regulated by the following rules:
http://forums.aussieveedubbers.com/viewtopic.php?tid=35871
[ Total Views: 15529 | Total Replies: 217 | Thread Id: 68032 ]
 Pages:  1  ..  6  7  8
Author: Subject:  NOW AVAILABLE FOR ORDER: "Kafer Cup" Style Bars
MemberAussie Dubbin
Threads: 20
posted on July 27th, 2010 at 06:22 PM
HI Craig, I have seen you talk about a rear solid and a mid-mount gearbox mount... have you fabricated anything here??? Are these kits in aid of using standard mounts ... or ... do we still need pretty beefy rear and mid mounts? (mid mount style i am thinking is similar to a gene berg mount with a plate mounted to the nosecone bolts and then supported to the frames via a utherane washer ((thick)) and a welded tab...)
Question is do we need solid mounts and do you sell them??? Pics
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 277
Mood: laying back having fun
posted on July 29th, 2010 at 10:18 AM
Originally posted by 666bug
Hey Craig,
payment sent :tu:
Cheers, Kit will leave today or tomorrow :cool:
Powered by Pobjoy 1916's for more than 2 Decades. :cool:.........Motors that 'punch' well above their weight and unmatched in performance :lol:
MemberCraig Torrens
Threads: 277
posted on July 29th, 2010 at 10:35 AM
The K Bar kit stops the forks from flexing and also stiffens the chassis in the rear via the triangulation of the bracing..............what it doesn't stop is the gearbox moving in relation to the forks, this being caused by theflexing of the rubber mounts under load.
To get the FULL benefits from the K bar kit, then YES you need to uprate the gearbox mounting from the standard setup.
In my Ragtop (roadcar setup) I have used the CB Performance Rhino gearbox mount kit, with a strap over the bellhousing and and a mid mount strap kit. This works very well, but in some instances i get very minor tramp.
With my 76 road beetle that is now being used for street drags, I have solid mounted the gearbox via a custom cradle and the berg style mid mount that is solid (no urethane washer). This is the best solution for race applications and minor road use, but if you have a street beetle/daily driver then I would suggest the rhino mounts.
http://www.cbperformance.com/catalog.asp?ProductID=643
http://www.cbperformance.com/catalog.asp?ProductID=641
I have a solid kit available for sale, pm if youre interested.
MemberCraig Torrens
Threads: 277
posted on July 29th, 2010 at 10:38 AM
Originally posted by zayus
Does the 3 point brace work with heater boxes?
Have you had an opportunity to check, whether the torque bar fits with heater boxes?
Like Funbug, I'm interested in running the 3 bar set up with heater boxes.
Thanks.
Will find out this weekend :cool:
Now Containing 100% E-WANG
Threads: 182
Mood: Lovin that Subi sound
posted on July 29th, 2010 at 11:50 AM
Mine didnt clear, the left heaterbox hit the bar with the bellhousing about 1" from home
Volkswagen: Turning drivers into mechanics since 1938
Memberfunbug
Threads: 16
posted on July 29th, 2010 at 09:46 PM
Joel how did you overcome that?
Threads: 182
posted on July 29th, 2010 at 09:54 PM
I ditched the VW engine :lol:
sorry not much help.
I had to run Jpipes to get it to fit
If you got creative with a welder and some pipe you might be able to send the heaterbox around the the bar
Member71-BEETLE-SEDAN
AKA Josh
Threads: 108
posted on July 29th, 2010 at 10:26 PM
Would a ball pene hammer help it fit, maybe dent the heaterbox enough?
1971 Beetle Sedan Daily Driver
1964 Beetle Sedan Restoring
 Pages:  1  ..  6  7  8
Powered by UltimaBB, © 2004-2007 The UltimaBB Group
Copyright © 2002-2008 Aussieveedubbers. Aussieveedubbers is not responsible for members' posts.
[ Queries: 31 ] [ PHP: 6.3% - SQL: 93.7% ]
