| [ Total Views: 909 | Total Replies: 40 | Thread Id: 85050 ] |
| Pages: 1 2 |
jedidan
Threads: 31
Mood: Always cool.....Air Cooled !
| posted on July 29th, 2010 at 08:33 PM |
yep will be going ! my first time EVER ! looking forward to finally meeting you Lee. Unfortunately i wont be bringing the humble semi-auto this time,
but a bright 'falconio' orange camper !
See everyone there !
Daniel
IF I'M GOING TO HELL, I'M GOING IN A VW BEETLE
My Family's Swiss VW Buggy Legacy --------> CLICK
HERE
68AutoBug
Beetle Restorer - Experience over 100\% - YIKES -
Threads: 326
Mood: REALLY MENTALLY ILL -- ALL OF THE TIME
posted on July 30th, 2010 at 09:50 AM |
WELL...
I haven't....
I'm leaving SCONE NOW.....
travelling north.... then east,,,
donn
Threads: 157
Member Is Online
Mood: LAID BACK AND CONFUSED
| posted on July 31st, 2010 at 11:38 AM |
OK!, how the hell does a sump plug remove itself from a sump while travelling along at 110 and then no gauges or lights come on, anyone got a good
twin port they don't need or do I rebuild this one..Shit!!!!!!!!!
Brian
| posted on July 31st, 2010 at 03:11 PM |
easy it was left loose
Daehkcid N kkhhhedbbdfrr
donn
Threads: 157
Member Is Online
| posted on July 31st, 2010 at 03:17 PM |
Not so easy, though thats the answer I would have given to another person asking the same question I noticed that it was a bit loose a week or so back
and tightened it myself, used a ratchet ringie to do it up nice and tight, now I have to decide between doing the motor that I have or replacing it.
HappyDaze
Threads: 30
| posted on July 31st, 2010 at 03:26 PM |
Hope you didn't go too tight and strip the thread - easily done.
vlad01
Threads: 17
| posted on July 31st, 2010 at 04:22 PM |
you haven't painted the sump plate? This happen to my crumpledore lucky I caught it in time (only after 300k break in run ), then the water pump pulley bolts came loose as well as few other
bits.
It came down to the paint. You see paint is rubbery to some degree and even though its tight the paint would soften from heat and the pressure would
squeeze it out slowly and therefore the gap
between the bolt head and surface would slightly increase and make to bold come loose.
I just cleaned the paint off around the bolt hole and head re tightened it and problem solved. Realizing this I checked all other repainted surfaces
and sure enough they were loose
Just a thought.
donn
Threads: 157
Member Is Online
| posted on July 31st, 2010 at 07:56 PM |
No paint, deep sump (alloy) no striped thread in fact when we found the sump plug, about 3 k's back up the road at a rest stop in a puddle of oil I
found that it was pretty damned hard to screw back in, I figure it was all but out when I crossed off the road onto the rest stop area, I heard a bit
of a scrape as I crossed the drain at the edge of the road and that must have been the bit that took it out as there was damage to the thread in the
sump only on the last bit of thread.
modulus
A.k.a.: Peter Hill
Threads: 68
Mood: modular
| posted on August 1st, 2010 at 04:54 PM |
Sorry to hear of your loss....
It's probably worthwhile to safety-wire the new one.
hth
| Error |
Peter Hill
1975 Type 2 Double Cab
donn
Threads: 157
Member Is Online
| posted on August 1st, 2010 at 05:15 PM |
You can bet thats gunna happen Peter, where does the wire go to, another bolt?, I have already designed a plate to fit around the sump plug which I
was going to fit to another bolt in the round plate that the sump plug is fitted to but sounds like I may be reinventing the wheel.
modulus
A.k.a.: Peter Hill
Threads: 68
Mood: modular
| posted on August 1st, 2010 at 05:21 PM |
| Quote: | Originally
posted by donn
Just search for 'safety wire' in Google or similar and you'll get more information than you can eat. In summary, you can drill the sump plug
yourself, then wire it to and convenient point and twist it up tight. Often used on aircraft, as the consequences of the propeller falling off are
kind of terminal.
hth
Peter Hill
| Pages: 1 2 |
