[ Total Views: 188 | Total Replies: 5 | Thread Id: 85062 ]
Author: Subject:  upgrading a '65
Memberphoenix_dr
Threads: 4
Mood: relaxed
posted on July 28th, 2010 at 09:08 PM
upgrading a '65
Hi all,
I'm fairly new to this site and I was wondering about motors. More specifically, the relationship of motor size/output compared to NSW road legal engineering upgrades.
for arguments sake say I was to upgrade a '65 beetle from its standard 1200 to:
a mild 1600tp
or 1776
or even a 1915/16... or BIGGER?
(all of these would have exhaust and twin carbys of some sort).
would I need an engineers certificate for any or all of these choices?
at what point do you have to (legally) upgrade:
the brakes, from the standard drum - the suspension - seatbelts - windscreen wipers - to something better?
any advice would be greatly appreciated,
Thanks in advance
"So, when will the bug be finished?"
a better question is: "will it ever be finished"..
Super Moderatorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 225
posted on July 29th, 2010 at 05:58 PM
ok the biggest engine size without an engineers is 1700 for a bug.
I'm from the govt and I'm here to help
the chaos project
Threads: 545
Mood: V Forced!!
posted on July 29th, 2010 at 08:41 PM
Beg to differ Barls :crazy:
1700 is correct if you are working from a 1600
I am 99% sure (in NSW) self engineered is a 15% increase
So - based on a 1200 you are looking at a 1380??
That said - bugger all people would know the difference
As for the brake upgrade - again in NSW - once you upgrade to a 1600 you need the equivelent brakes
ie discs up front
Legeally - you really are better off going with a later pan that already has a 1600 and discs as standard
or just get it engineered
Upgrading the brakes is just common sense
Suspension - just needs to be in good nick
Decent shocks and good bushings/ball joints / K&L pins all round
You also need to think about a later gear box
A big motor and a 1200 box is a headache
Scilicet putas te currum reficere posse - stipes es!!!
Memberphoenix_dr
Threads: 4
Mood: relaxed
posted on July 31st, 2010 at 05:35 AM
Cheers guys, Bizarre that helps alot.
I was thinking about changing the pan, it would make sense...
but, I kinda like the idea of keeping it mostly stock except for a bigger motor/gearbox/ etc. That and I'm a fan of the wide five wheels (I know its a silly reason for not doing the obvious upgrade, but, meh).
will a 1500 gearbox fit in a 1200 pan? (it should)
As for the brakes does anyone know of a wide 5 disc conversion in Australia?
I've found empi ones in the US. Anyone have any thoughts on these?
I've been around veedubs since I was young bUt I haven't tinkered with one for about 10years...
with that in mind;
As far as gearboxes/ motors and other spares go who has the broader (cheaper) range in sydney?
Volksbahn?
Vintage veedub?
(Is tooleys still around?)
Any others I'm not aware of?
Will post up some pics of my project soon...
Threads: 225
posted on August 1st, 2010 at 07:26 PM
tooleys is still around and quite helpful there is also fermans in penshurst.
the chaos project
Memberphoenix_dr
Threads: 4
Mood: relaxed
posted on August 3rd, 2010 at 09:49 PM
Cheers Barls
Powered by UltimaBB, © 2004-2007 The UltimaBB Group
Copyright © 2002-2008 Aussieveedubbers. Aussieveedubbers is not responsible for members' posts.
[ Queries: 23 ] [ PHP: 8.5% - SQL: 91.5% ]
