| [ Total Views: 182 | Total Replies: 9 | Thread Id: 85064 ] |
oval TOFU
Bitte, ein Bit!
Threads: 230
Mood: :booM
| posted on July 28th, 2010 at 11:09 PM |
Dwell vs advance angle
Are the dwell and advance angles the same? I have a strobe light - can I tell what the advance angle is with that even though I don't have a degree
pulley?
Chris
johny rotten
Threads: 4
| posted on July 29th, 2010 at 06:27 AM |
Dwell angle on a 4 cylinder engine is 50 degrees
you can check the ignition timing with a strobe light if you understand the OEM pulley marking system
the dimple on the outer edge of the OEM pulley is TDC
ian.mezz
Threads: 200
| posted on July 29th, 2010 at 01:21 PM |
dwell is the time that the points are closed. Its just a different way to set your points.
You use a multi meter to check the dwell and it may vary due to worn dissy shaft.
Advance is either vacuum or mechanical
Vacuum advance is on Cruz to give you better fuel economy
Mechanical is on take off to give you more power.
68AutoBug
Beetle Restorer - Experience over 100\% - YIKES -
Threads: 326
Mood: REALLY MENTALLY ILL -- ALL OF THE TIME
| posted on July 29th, 2010 at 01:32 PM |
| Quote: | Originally
posted by oval TOFU
pulley?
Chris
You use the dwell meter to set Your points...
although I haven't used My dwell meter for probably 20 years..lol
the strobe light will show Your distributor advancing..
but You really need a pulley with the degrees on it to see the degrees...
or measure the degrees, off a degree pulley and mark them on Your pulley
say 28 degrees.. 30 - 35 - 40..
oval TOFU
Bitte, ein Bit!
Threads: 230
Mood: :booM
| posted on July 29th, 2010 at 10:44 PM |
Thanks for the responses guys. I'll set my points to 0.016" and double check it with the multimeter then.
It's a bummer I can't check the advance without a degree pulley then...
68AutoBug
Threads: 326
posted on July 29th, 2010 at 11:59 PM |
| Quote: | Originally
posted by oval TOFU
I can run a tape measure around a degree pulley for You and take pics...
its a bit difficult for You to mark the furthest advance on Your pulley when the engine is doing 3000 rpm... lol
You could put a few marks with a white pen etc..
until You find the correct one and measure from the TDC mark and I can tell You what degrees it is...
| Error |
| Error |
| Error |
oval TOFU
Bitte, ein Bit!
Threads: 230
Mood: :booM
| posted on July 30th, 2010 at 09:25 PM |
Hey Lee
Thanks for going to the effort!
Perhaps you could give me the length of the green arrow (30 dgrees) and if you can 32 degrees too? Presuming the flywheels are the same diameter and
my high school maths if correct, the chord length should be the same too!
booyah (I think)
ctefeh
Threads: 25
Mood: grimly determined
| posted on July 31st, 2010 at 12:17 AM |
http://www.vw-resource.com/tune-up.html#preliminary
Here ya go, no need to stress on the maths, all explained!
HTH
Ctefeh
oval TOFU
Bitte, ein Bit!
Threads: 230
Mood: :booM
| posted on August 2nd, 2010 at 09:51 AM |
Gold. I should've thought to look on there in the first place!
Thanks Ctefeh - that does help!
alien8
Threads: 77
Theme: UltimaBB Powder
Mood: A bit to the left
| posted on August 2nd, 2010 at 10:18 AM |
Hey mate, thought this pully chart might be of intrest. print it out line up TDC with dimple on the stock pully and file notches where you like. I
usuall mark BDC for adjusting valves and a 30* mark for timing. Its good to check the stock notches on a stock pully just to see what you have too.
| Error |
