[ Total Views: 166 | Total Replies: 7 | Thread Id: 85079 ]
Author: Subject:  Anyone use Iridium Spark Plugs in Air Cooled engine??
Super Moderator68AutoBug
Beetle Restorer - Experience over 100\% - YIKES -
Threads: 326
Mood: REALLY MENTALLY ILL -- ALL OF THE TIME
question.gif posted on July 30th, 2010 at 12:08 AM
Does anyone use Iridium plugs in their Beetle....??
Been told they are great in Motor Bikes...
also expensive...
How much are they??? are they worth it??
- Helping keep Air Cooled VWs on the road - location: SCONE in the Upper Hunter Valley - Northern NSW --- check out My websites at:--
Membervlad01
Threads: 17
posted on July 30th, 2010 at 09:28 AM
No i don't think they are that good. Gene berg did all these tests and found the bosch plugs to still be the best.
The bosch super 4's are suppose to be proven to be one of the best plugs out there and less than half price over the iridium plugs.
Question is? can you even get supper 4's for vw or even 3/4" version? I don't know.
http://i1015.photobucket.com/albums/af278/vladk01/vdubsig2.png
MemberBiX
dirt demon
Threads: 146
posted on July 30th, 2010 at 10:59 AM
I use them in my VW engines. (also the motorbike). The main advantage I found was that becuase they are irridium, they run a much finer tip, almost like the oldschool race plugs. I found this stopped plugs from oiling up as much. The new engine has 48idas on a 2L motor, so if you use to much throttle allot at low revs you tend to almost flood the engine. Normal plugs would foul.
The cost is much higher (about $80 to 100 a set) but i ran them for 2 years with no problems or changing them in my old 1776 and will probably run them for 1 to 2 years in the 2L. They were designed for newer engines so that they could be left in for long periods and reduce costs during servicing, when you had to get through a heap of plastic to get to the plugs.
basic.... yes they are expensive, but worth it and you get the cost back over time.
Go hard or go home!!!!
MemberPhil74Camper
Head in the Clouds
Threads: 105
posted on July 30th, 2010 at 02:00 PM
For a modified high performnce engine, hey why not, you might as well try them.
For a stock VW engine, use the recommended stock-spec VW plugs (Bosch, Beru, etc). They are much less expensive and provide all the performance you need in a stock motor.
Memberbus914
Threads: 148
Mood: Could be worse.
posted on July 30th, 2010 at 08:33 PM
"Performance" comes from the extended gap. The extended gap means there is more likelyhood of ignition so you get less "misses". More gap is possible with an Iridium plug because the finer point is better at ionising the gap.
The finer point also reaches higer temp quicker therefore is better at keeping itself clean, this means less fouling.
http://i4.ytimg.com/vi/KOKlJpsfCyk/default.jpg Click the thumbnail for video:yes:
Membervlad01
Threads: 17
posted on July 30th, 2010 at 09:44 PM
yep and for standard aps these suck, but high comp or boosted engines these work good.
Also a extra HV ignition system is a must otherwise a performance loss will be experienced.
Memberjsheppard64
Dry Start!! yay!
Threads: 17
Theme: UltimaBB Psyche Red
posted on July 30th, 2010 at 10:54 PM
What would be the plug number on the iridium??
my local super cheap doesn't stock the bosh W8AC
so i've been running NGK BP5HS or was it BP6HS?? hmm
anyway I've been using them for 2 years until i fouled them with HS6 SU conversion lol
Memberbugzla
Threads: 93
Mood: always happy
posted on July 31st, 2010 at 08:19 AM
in my mates r33 we found using cooper plugs rather then iridiums we found that there were less missfires and fouling problems under boost ill be staying with coopers :smilegrin:
Powered by UltimaBB, © 2004-2007 The UltimaBB Group
Copyright © 2002-2008 Aussieveedubbers. Aussieveedubbers is not responsible for members' posts.
[ Queries: 23 ] [ PHP: 3.5% - SQL: 96.5% ]
